Define 'good'.
From the prices (and the lies) I have found on craigslist, most belt-driven driven presses are either worn out (and abused) by a wood worker, or abandoned by a metal worker.
Don't trust those 1.75 inch driving pulleys to transmit any useful torque, it's not possible. You will have trouble drilling 3/8 inch holes in 1/4 inch plate.
I have had to learn (with my money, not a teacher) about this class of machine. I will post a few 'gotchas', it's up to you to ask for more information, or to learn more on your own.
Does the machine have a belt-tension adjuster? I'm not making this up, I have a Dayton drill press that didn't have an adjuster.
Release any depth stops, and move the chuck all the way down. Rotate the chuck by hand. Is it still connected to the belts and motor? Yes, I have one of those drill presses, another Dayton.
Does the quill spider downfeed feel loose on its shaft? The Dayton I mentioned had no shaft key installed it only had a set screw.
Take a good hard look at the driven step pulley. Does it have a keyway? The Dayton unit had no keyway to secure the step pulley to the spindle.
For all intents and purposes, a belt-driven drill press is a crap shoot when it comes to drilling holes in metal; those small pulleys cannot transmit adequate torque, and there is no easy modication, it isn't just a matter of "tighten the belt".
My Delta (with the laser pointer) has a tensioner, but I didn't apply a cheater bar to it, and it slips when drilling 3/8 inch.
Yes, you are speaking of Delta, but I don't think anyone should place blind faith in any brand name, nowadays.
