SUMITOMO’S INTRODUCES TSX SERIES FOR HIGH EFFICIENCY SHOULDER MILLING
April 7, 2017 9:27 am
Mount Prospect, IL – New from Sumitomo Electric Carbide, Inc., the TSX Series Tangential Milling Cutter is designed for exceptionally efficient shoulder milling.
For stable, highly efficient machining at high feed rates, the TSX Series is engineered with a tough and sharp cutting edge. It provides the strength required for increased depths of cut ranging from a small job to a heavy duty roughing application.
A 4-corner ground tolerance tangentially mounted insert, with an optimized chipbreaker, achieves excellent edge sharpness and sidewall accuracy. The TSX is available in two precision-ground insert sizes offering a maximum depth of cut of 8mm (.315”) and 12mm (.473”).
Other features of the competitively priced TSX include reduced cutting force, surface roughness Ra under 0.5 µm, squareness under 0.05mm and long-term wear resistance.
For more information, contact Sumitomo Electric Carbide, Inc., 1001 Business Center Drive, Mount Prospect, IL 60056, Phone: (800) 950-5202, Fax: (847) 635-9335, e-mail: [email protected], or visit the Sumitomo website at www.sumicarbide.com.
