Fresh ground chuck - mmmmm tasty
Just got done grinding in a mag chuck for the first time, the fine pole electromagnet chuck on our Boyar-Schultz Challenger 618 at work. It came out great and I just wanted to thank all the regular contributors here for all the terrific information I was able to glean which helped me to do this with relatively few problems. In fact the only difficulty I ran into I'll share with you, you might get a kick out of it...
I had taken a few passes with good results, but still had a few more to go to grind the low spots all the way out of the middle of the chuck. Out of an overabundance of caution, this being my first rodeo grinding a chuck in, after each pass I'd attach an indicator to the wheel guard and indicate the fresh ground portion of the table, to make sure I was seeing what I wanted to see. I was getting good, repeatable results, until one morning I came in, took a pass of about .0003" deep, then put the indicator on and the damn thing read like diamond plate. Dressed the wheel, took another pass, same deal. Frustrated, I decided to walk away for awhile, collect my thoughts and decide how to proceed. I started another job I had on my bench, a one-off lathe part. I was indicating it in on the four jaw on my lathe, which sits not too far from the grinder, when the needle on my DTI started dancing all over the place. I'm sitting there going WTF, and I notice the needle fluctuations are oddly rythmic. That's when the noise registered in my brain.....
KA-CHUNK, KA-CHUNK, KA-CHUNK.....
The Trumpf CNC laser/punch press right next door to the grinder area was embossing some stainless parts and sending little mini earthquakes through the whole floor of the shop, and throwing my poor mag chuck mercilessly into the wheel as I ground. I don't know how I didn't realize it sooner; I've got my ear pretty well tuned for when things go wrong in the shop, but I guess the sounds of normal operation just sorta blend into nothing. And through freakish coincidence, I had been indicating the chuck, both times, while they had been loading the press with material. I waited till they were done with the run they were on, made another couple passes, problem solved. Live and learn, eh?
Anyway, thanks again, guys. I now have a chuck suitable for a couple tool grinding jobs I've got coming up, and I probably couldn't have done it without the information I'd gotten from here.
