Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > Abrasive Machining (New Forum)
Abrasive Machining (New Forum) Discuss grinding and abrasive techniques and machines
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 11-18-2009, 01:27 PM
Quote:
I often rough at .025 depth with about .002 - .005 infeed per table reversal on the ancient B & S, & over .040 sometimes on my DoALL D10. the cut is all on the side of the wheel. For many operations, it cuts cooler and leaves the part more stable.
I have always found that the depth of cut is only limited to the amount of horsepower available. Of course the edge of the wheel is going to take a beating and you have to adjust the rate of in feed. Depths of .025, .050, .075 or more are all readily achievable. You'll have to have the proper grade and grit of wheel but you shouldn't be afraid of pushing the envelope. If you have an automatic grinder and can reduce the in feed to the desired level all the better. You can then walk away and do something important. When the wheel sounds like it is crunching you can be assured that all is well. If it is screaming then you need to change one of the parameters or maybe change the wheel.
Gene
  #22 (permalink)
Old 11-18-2009, 07:41 PM
cash's Avatar
Cast Iron
Quote:
Originally Posted by John in CA View Post
Interesting information, cash. Since you guys have made the move to all ceramic, I'll ask:
You say the man-made abrasive likes to be pushed a little harder, which I presume means its optimum performance is at slightly larger than normal depths of cut. How do you find they perform for dusting off that last two tenths, in say A2 at 62 RC, compared to a straight aluminum oxide wheel?
With a fresh dress on the wheel dusting off the last couple tenths is not an issue. When you are in the stock removal mode then this is where you want to push the wheel as hard as you can.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
