Pattnmaker
Stainless
- Nov 2, 2007
- Hamilton, Ontario
I am designing a ductile iron casting that will be a flat plate about 3.5" thick and about 12" square. It will have a bunch of cored holes through the 12x12 face. I want to flatten both sides of the casting to remove small steps .030" left in the face from draft in the coreboxes and to level things out after the foundry's grinding off of flash. I am thinking I need to remove 1/16"-1/8" per face. Final thickness is not critical. I just want 2 cleaned up faces that are fairly flat.
I will be doing these in batches of 50-100 at a time. Is blanchard grinding the best/cheapest way to do these? A decent face milled finish would be acceptable but sticking these down on a mag chuck will be much faster than clamping in a mill, but I have no idea about the grinding speed.
