Spud
- Jan 12, 2006
- Brookfield, Wisconsin
I have a Lapmaster 15 benchtop lapping machine.
What is the best method to clean it and what kind of products should I use and what products should I Not use?
I presume it would be fine to clean the Lapping plate , Lapping Rings and Weights with Acetone?
Isoprophyl Alcohol, Denatured Alcohol ??
I do not have a Parts washer or Ultrasonic Cleaner. So manual cleaning is the only option I have.
Re. Corrosion protection
Is it ok to spray corrosion inhibitors like BoeShield onto the Lapping Plate, Lapping Rings and Weights? What about WD40 corrosion inhibitor? Unit will be stored in a rental garage after cleaning, so somewhat concerned with corrosion due to the climate here.
