tribologist
Cast Iron
- Jun 12, 2010
- Connecticut
This last weekend I got a good deal on a little Covel No.6 that will be able to do what I need. It seems to be capable of doing basic OD/ID grinding and also light surface grinding. I have a Precise 30 spindle and a adapter that will bolt right on to the face of the main spindle so it should work great.
Great little machine and i'm all exited over it!!
I found a good description of its various accessories in http://www.iamachinery.com/brochures/scans/0013.pdf and I got the parts manual from Clausing.
I tore it down yesterday to clean it up, possibly repaint it. The slide ways are great, all the flaking is intact.
I need to replace the main bearings since they are filled with totally gonked up grease but it uses regular 6206 ABEC 5, deep groove ball bearings so the cost is reasonable, I plan to find some shielded or sealed 2Z or 2RZ bearings to make it easier to keep them clean when assembling. (Clean ABEC-3 bearings are way better running that a ABEC 9 bearings with particles in them...)
The only real problem I found so far is that there is some damage on the taper for the main grinding wheel and I did not get any wheel adapters. The PO had made a extension on it that threaded on to the spindle (that has 0.007" runout..). I will most likely have to re-grind the taper but I would need to know the angle (and find someone with a grinder, I might be able to go to the buyer of my previously owned Covel 512 and ask him for help but I'm not sure if he can set the table that much. That machine did not have the universal work head.
The gentleman I talked with a Clausing did not know the specification on the adapter.
Any chance someone here knows? Anyone with an adapter for sale?
I also need to find a suitable work head, ideally one with 5C or MT2 taper since I have plenty of collets in those sizes.
Any help is appreciated.
Ulf
Ulf
