Hey,
I'm pretty new here and I have a grinding question so I figure I'd ask here. We have a DoAll G1 surface grinder in our shop and I have some parts that I'm trying to figure out how to finish. I don't have much experience grinding so bear with me. Picture the parts as a tube of chap stick but only about 1/3 of the length. These parts need to be ground on each end to meet OAL, flatness, and perpendicularity callouts. The datum surface is the OD. I have an idea in my head that I think would work but I don't know where to find something like this. In my head if I had a block with multiple V's that was almost as thick as the part is long. I could put several parts in it and tighten them down with a flat edge, grind one side, flip the parts, and then grind the second side to the overall length. I think this would also give me the flatness and perpendicularity callouts I need to hit. I was thinking I could even use two of these v block things, one on each side and some wedge clamps in the middle to double the amount of parts I could do at once. I drew a picture of the basic setup because I'm sure I'm doing a poor job describing it. Anyway, does something like this already exist and is readily available? If so, any tips on finding it? If not, do you guys know of anyone who makes custom v-blocks and could do this? We have something similar in our shop that we made in the past but we aren't a tooling shop and I'm looking more accuracy than I feel we can make. I'd also be happy to hear any other ideas you may have on how to grind these parts. Any input is greatly appreciated. Thank you!!
