My shop drills a lot of baffle plates - Basically 1/2" CS/SS, up to 100" OD. We stack the plate to roughly 7" or so, weld, setup and drill. For example, a 50" baffle may have 2000 3/4" tube holes (.759 typically). The drilling process leave a small burr that can damage the outside of a tube.
I need a machine to quickly debur the part, top and bottom, and then move onto the next. In my example, I have 14 plates, 1/2" thick each, and then I drill 2000 3/4" tube holes in each stack, so when I break apart the stack I create 28,000 holes to debur, top and bottom. I have seen home brew machines that use a gantry and several motors with wire brushes on them and the plate is conveyed across the brushes. Looking to buy something, not build something.
Any thoughts would be great.
