aj
Hot Rolled
- May 12, 2006
- Burlington, North Carolina
First, let me say I'm not a grinder. I'm usually lurking over in the CNC Machining forum. I've run O.D., surface, blanchard grinders, but I don't do it often enough to be called proficient at it.
My question is simple. What do you call the little white(ish) sticks you use to remove the build-up on CBN wheels? They wear away quickly and I need to find out what they're called so I can order a couple. I need to get least one for our pedistal grinder.
I've asked no fewer than 3 people (including our local grinder guy) but never received an answer. So I thought I'd post the question here in hopes of finding out.
Thanks, guys.
Thanks, guys.
