Damien W
Stainless
- Aug 3, 2006
- Brisbane, Queensland
One method of cylindrical grinding is plunge machining. I suspect it is restricted to short workpieces often for form grinding to impart a particular shape. An example of this might be an NTBA 40 or 50 arbor or adaptor.
One application is to machine a taper or even two adjoining tapers of different angles (again requiring the wheel to be modified for a form grind).
In the case of my Russian universal cylindrical grinder the specifications say that the standard wheel is 350mm maximum diameter by 40 mm wide (again maximum so that probably answers one question). So plunge grinding is limited to 40 mm wide. If you want a taper wider than that is it possible to fit a wider wheel so the taper can be plunge ground? The manual says that the wheel guard is 50mm wide inside.
