rj newbould
- Aug 29, 2005
- Hernando, FL
One of the big PITA things is trying to get a nice straight grind on a long pin. I've been through the shimming routine and hated it.
Here is an easy solution to the problem. I have two 3/4" plates bolted together in a tripod fashion. Two widely spaced 1/4" bolts with a common flat washer between the two plates on the back rail end, as per the following pics.
An overall view.
Showing the two hinge point bolts.
Shows an indicator mounted to the bottom plate to adjust taper.
Showing the third leg of the tripod, a jack screw and a pull down screw.
This arrangement works like an 11" sine plate setup with no gage blocks, making it very easy to very accurately adjust out an unwanted taper, or to create a small taper.
An overall view.
