928gene928
Cast Iron
- Sep 13, 2005
- Joliet, Illinois
What is the best way to check and or adjust a harig 6x12 spindle? Have notice that the quility of my surface grinding isn't the best (mostly mild steel), has a slight ripple type surface under magnification. Have tried various wheels etc., and it does not feel like there is a loose bearing. Have not used an indicator as yet to check the endplay. Usually allow the spindle to run for awhile prior to grinding, after use the spindle doesn't develop much heat, but have not measured the temp. as yet. I did notice that the coupling between the motor and spindle isn't what I would call super tight, the rubber spider between the two coupling halves has been replaced.
