Hobby Shop
Stainless
- Mar 20, 2014
- Michigan
Hi guys. I need some help getting my grinder up and running. It's a Harig Super 612. The PO removed the Teflon from the ways and the oil pump from the machine. After that, they set it in the corner because they couldn't get it to grind flat again. Does anyone know the thickness of the Rulon 142 I need to order? McMaster carries it in 6"x6" sheets ---1/32",1/16" & 1/8". Is it best to have a continuous strip or is it ok to piece it together?
Unless someone steers me in a different direction. My plan is to clean/scratch up the ways really well, epoxy the the 142 down and set the table back in place. Then, scrape the 142 to the bottom of the table.
Andy
Andy
