otn
- Mar 4, 2003
- San Diego, CA, USA
I have a barrel that has a bore that a .311" gauge pin will fall thru but a .312" pin will not. I'd like to drill this out to .5" using a piloted drill. I plan to grind the pilot on the surface grinder using a motorized spin fixture and resharpen the ground ends on the T&C grinder.Questions include:
1. How to hold the 6" drill for grinding. Four inches of drill out in front of the collet makes me nervous. Would it be best to drill out a brass 5c collet and hold the drill by it's flutes or hold it by it's shank and support the tip? Or?
2. Is there a general rule regarding pilot length? In drilling a bore that measures .3115 with the piloted drill would it be best to use a .311",.312" or ? diameter pilot.
Thank you for any help in answering these questions.
Otto
Otto
