Mike C.
- Nov 25, 2004
- Birmingham, AL
Hey guys, kinda been thrown at this old WWII era Landis 14x96" Landis roll grinder since the other guy in the shop quit a few months back. I am fearing the spindle bearings are slap worn out, but wanted to get some other opinions. On small work (under 4"), it is OK, but on larger work it is HIGHLY prone to chatter and you take nowhere NEAR the amount off that you put on the dial... like I ended up putting about .060 total on the dial in .005 increments today and took only about .015 off the diam. This workpiece was a solid steel rod 13"x60" and I was grinding hard chrome plating to size. End result was great, within .001, end to end, but the time it took was ridiculous because it just wouldn't cut.
As massive as this machine is, and given the size of the rock and the spindle motor, am I wrong to think this thing should never notice a .0025 depth of cut? Am I pushing it too hard? Should I be upping the rotational speed of the work and/or upping the traverse speed of the table to eliminate this chatter, or are the bearings just toast and I have to live with what I have? In other words, am I doing this wrong or does this sound like a problem with the machine?
