Peter from Holland
- Jan 15, 2005
- The Netherlands
I have an old Jung F40
For a while it functioned as it should
But now the table movement does not work propperly
It has 2 pushbuttons One to move the tale to the left and one for the right These are actuated by a adjustable cam for each pushbutton
If the cam actuates its designated pushbutton the direction of the table is reversed
The problem now is that the leftside button only functions at very low speed
At higher speed it overshoots These puschuttons are electrical The electrical functions I checked and are fine
If I put the speed all down and actuate the buttons on the right one I here a noise from a valve probably
On the right one I here the same sound but it sound like the valve actuates slower
Anyone else had that problem and knows how to fix it
I hope I don`t have to take it apart
Peter from Holland
Peter from Holland
