Hi
I am trying to remove the grinding wheel to rebalance and have come up with a problem.
The manual said to "remove the fixing screw in the spindle", yep did that, left hand thread no problem.
"The supplied extractor screw screwed in instead, (ha no supplied extractor thread). "By driving the latter the wheel collet is removed from the taper of the spindle"?
I can't see how this happens as there is no thread on the collet for the extractor to screw into the collet?
Only thing I can see to do is undo the bolts in the collet and remove the front flange and wheel, then apply some gently heat to the taper. Or remove three of the 6 bolts say, and make up a puller plate that pulls by the collet bolts and bushes on the end of the shaft and try and pull the hub/collet of the spindle?
I want to keep the wheel mounted to the collet to see if the balance is out or if I have another problem.
Wheels should be 16" x 1 1/2" x 5", but either the wheels that came with the machine are worn down or the PO fitted 12", I have 4 wheels and they all measure 12", details on the sides of the wheels have long time gone, 3 white ones one pink?
Burgs
Burgs
