Hi All,
I need to lap and polish advanced ceramic components that I'm manufacturing. I'm looking into purchasing a machine (surplus), but I'm not sure what is needed for the job in terms of equipment, tooling (wear plates, I believe they are called), and consumables (grinding grit / paste).
The largest part to be lapped / polished is 4" square. The spec given was a surface finish between 16 and 4 microns, lapped flat to 16 hlb or better, with .002" or better parallelism for top and bottom.
A 15" lapmaster looks suitable, but I've found surplus machines that may do the job for thousands less. Would something like a spitfire sp-ml-15 work for this job?
Also, any practical guides/reference books that would be a good resource on lapping and polishing?
