Haveing had the grinder for just over a month now i need to get on and grind the chuck (Its covered in nicks - rasied dents, have stoned of the worst but it needs a skim). The niggles have all been sorted except one. The handle on the chuck is incredably stiff. I know magnetic chucks are never smooth but this is just taking it a bit too far. Its a struggle to energise it, too the point its a two handed job.
Therefore before i grind the magnet im contemplateing takeing it off. I am guessing there must be some fastners holding the back on. Is it possible to remove the back and get at the handle mechanism and clean - lube it up? The chuck in question is a elliott walker fine pole 18x6". Google gets me no where with that name. just a load of secound hand dealer hits. Even if it is fastened can i take it apart or is the magnetic pull to great?
Adam
Adam
