Peter S
- May 6, 2002
- Auckland, New Zealand
I have recently bought one of these machines, in a filthy state but hopefully still in reasonable order once cleaned up. It is a smallish machine, weighs about 2 tons, can handle about 600mm between centres. The grinding wheel is about 12" diameter x1" wide. This particular machine has the wheel retract option. The workhead is driven by a Kopp variator. The internal grinding attachment hinges down from above.It is a metric machine.
At this stage a handbook and parts book would be really helpful. Can you help?
Tony at lathes.co.uk sells them (photocopies) for £75 each and Matrix will sell them at £100 each for pdf copies. I don't want to spend this much, hence my request.
Does anyone have experience with these machines? Matrix is probably best known for their thread grinders, several of which I have seen in NZ. Up until the late 1960's Matrix was the trade name for the long-established Coventry Gauge and Tool Ltd. In those years they made jig borers and slip gauge sets as two examples from a large range of rather nice gear branded "Matrix".
The photo shows it as bought. I have already cleaned off a lot of oily, gritty grime and it is starting to look better except where the sheets of paint are falling off.
