I cleaned up an MSG-205MH (6x18 on the same chassis as the -200) last year. It had spent years cutting off pins, apparently, and was absolutely loaded with oily grit. The first cleaning pass was with a spatula. Fortunately, longitudinal ways were free of the grit. Cross ways were Turcited or similar, and look a bit worn and dirty, but I have not mapped out the wear to see if they need reconditioning.
Cross lead screw had a damaged boot, which I replaced ($35). Also put in a new set of way wipers ($220, ouch).
aerodark, I have an spare almost 6x18 fine pitch permanent magnet chuck in excellent shape. It's "almost 6x18" as it's metric 150x450mm. I intended to replace my old Walker chuck, but have been waffling about losing the extra fractions of an inch. If you think you can mount the 6x18 to your table, I'm sure we can strike a good deal, and I'm down I-5 in the Portland area.
