Need shop for surface grinding.
Results 1 to 10 of 10
    Mar 2015
    13
    Default Need shop for surface grinding.
    Hello,
    Does anyone have recommendation for a shop in the Philadelphia/South Jersey area that would do a small surface grinding job? I have one piece of machined cast iron that needs one side surfaced ground. It is about 6" wide and 17.5" long. Google searches come up empty. Thanks in advance.
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    10,783
    3902
    3661
    surface grinding philadelphia - Google Search
    Lot's of options.
    Call one that looks close and likely to take small jobs based on ad copy.
    If they don't want it or price seems high, ask who they would send a small job to. They'll mostly know each other, or of others.
    Out of curiosity:
    needs one side surfaced...
    What is the current condition? Is it a parallel part or will it need shimmed or other set up on the chuck? Some parts it's easier to kiss the back before doing the "good" side for both set up convenience, and minimizing warp from pulling a non-flat surface down to the chuck.
    What are the tolerances?
    Should it be ground on a recip, or is Blanchard OK?
    What is the application?
    smt
  3. Likes digger doug liked this post
    Mar 2015
    13
    Thanks for the help. I never tried searching for surface grinding, just machine shops. It is a new T-slot cross slide for my South Bend 13" lathe. The bottom slide surface was scraped to true and I need to remove the tool marks from the machined top. Blanchard is most likely fine.
    Aug 2005
    Tucson AZ
    5,834
    7712
    2650
    How bad could these marks be? If the surface is flat that is all that should matter.
    Mar 2015
    13
    The machine I was using had a couple of thousandths dip in the y axis bed, so each pass of the cutter left a small ridge.
    Sep 2013
    Oregon
    590
    375
    195
    Quote Originally Posted by genther View Post
    IMHO just use it as is it will not make any difference at all. Mount your tool post and be done with it brother.
  8. Likes Paolo_MD liked this post
  9. #7
    Jun 2012
    Michigan
    8,079
    2341
    2608
    Just for cutter steps and if close enough to function likely I would not have it ground..6 x 17” is a big part and will tend to get hot nearing full surface even running with coolant so if not a decent grinder hand having the right wheel could out a heat warp in it...likely to charge an hour shop rate....
  10. #8
    Mar 2015
    13
    Thanks for all of the input and I will take the advice.
  11. #9
    Jun 2003
    Mebane North Carolina USA
    6,161
    51
    1630
    If you went through the trouble to scrape oneside. Frost the other.
  12. #10
    Dec 2005
    Jersey Shore
    3,795
    276
    442
    I could do it, but there would a mark as the travel is only 12", so two sections would need to be blended. It would be more cosmetic, than metrological.
    Tom
