Some people may be confused about what a "stroke sander" is. So here is a picture. At least in the USA, a Stroke sander is a rather large (sometimes huge) stationary belt sander. The work goes on a table that can be raised or lowered, and the operator uses flats or forms inside the back of the lower run of the belt, to sand the work below. The flats or forms are faced with replaceable graphite cloth for slickness and to prevent heat build up. I have even seen graphite faced mittens used.
The operator "strokes" the table back and forth under the belt while manipulating the flat to sand flat surfaces.
With a form block, the table is held in place and the work aligned with the belt, then the operator strokes the form block along the surface to sand it to contour.
Some of these machines have auto stroking over a chevron graphite inner belt. Or have pads that are machine mounted and can be made to cycle automatically. Mine, in the picutres, was a Mattison originally set up auto when built in the 1920's. It may well have been used originally in metal fab. All the auto mechanism was long gone by the time I acquired it.
In the US, you can barely give one away. I tried to sell mine (pictured) a few years ago and no takers except one scam artist from offshore, lol. I'm glad no one took it, started to do work again for which it is invaluable & I would be vexed to not have one. Some of the work i do on it is large radius wood or metal parts.
I agree with Adama. Any machine that uses an abrasive belt is essentially abrasive limited, not HP limited. That said, 1HP/inch of belt width is indeed a good starting point. 5HP wworks quite well on my 6" x 300" (25' belt) machine. If setting up strictly for metal, I think 7.5 would be plenty, and that you would rarely if ever absorb 10HP.
I have used or been around others - I like the "Unusually" large diameter wheels on mine - good grip without rubber facing, and lots of room to work your forms, or to go up and over lengthwise curves. (though lengthwise curve is limited by how slack you can decide to run the belt. But again, large wheels help).
I've seen them as long as 15' between columns (*Euro-built machines.) Of course since the wheels are cantilevered, any length of narrow work up to about a 1' wide can be accommodated. Sometimes the Euro machines have the framework cantilevered as well, and even wide work longer than the machine can be accommodated.
The most difficult task about building one is the table raise-lower mechanism. A much older, now late, acquaintance of mine built a few back in the 60's /70's when such machines were still very expensive. He did beautiful fully functional work, too. German derivation name, of course.
smt
*It finally came to me after posting, I think the larger machines I've seen, especially the auto-stroker/chevron belt were made by Panhans. There are (or were) a lot made in Europe, and the Germans (Including Felder) and maybe especially Itallians (SCM/SCMI)exported a lot of the very small, and very large, machines to USA for opposite ends of the furniture market.
panhans stroke sander - Google Search Doucet (French?) also was popular, they made an unusualy 3-wheel/pyramidal machine with even more space at the center of the operator position.
Doucet stroke sander - Google Search Wadkin (England) was less common in the US, but built heck for stout. Really rugged machines.
