ADFToolmaker
Cast Iron
- Mar 12, 2012
- Hamilton, New Zealand
We are tool makers, we surface and cylindrical grind tool steel all day long, White aluminium oxide, pink aluminum oxide and Sg Wheels. Almost always using the periphery of the wheel, only side wheeling when we need to kiss a shoulder, because side wheeling always seems to be a painful process.
Then we get a 440B blade to grind, and using the periphery of the wheel (PA), limited success, so we are not the grinding legends we thought we were. We did notice the previous grind was done with the side of a wheel, cup wheel presumably. I have noticed many knives in industry are ground this way, maybe we should do the same? What are requirements for work and wheel speed? Wheel type? Can someone explain to me why using the side of the wheel succeeds for knife grinding when we see it as a last resort?
Andrew
Andrew
