After many hours of researching. I had reached the conclusion that I needed a CBN wheel for grinding HSS in my surface grinder. I contacted a company called Eagle Superabrasives. They specialize in CBN and Diamond wheels. They agreed a CBN wheel is what I need for grinding HSS however felt my machine was lacking with only a 1hp spindle. I would not see much benefit for the 5 times in price over an AO or Ceramic wheel. Here are my questions. Has anybody ground HSS using a CBN wheel? How does it perform compared to an AO or Ceramic? Do you think a 1hp machine would be under powered for removing .005" total material per side? I have 48 parts to grind. Even if I could only take .001" per pass I would be happy. Im taking .0005" per pass right now and I have to dress the wheel every couple passes. I want to be able to grind at least 2 parts at a time and do a couple sets before dressing again. Is there another type of wheel that works good for HSS that you have used other than a CBN?
Here is a few wheels I have tried.
Radiac 8BP46 G800 VOS
Radiac 8BP46 J8 V8
Radiac RA46 H8 V8
Radiac 8BP46 H800 VOS
Norton 5SG46-JVS
I use Q Cut 225C cutting and grinding coolant with water.
I have tried slowly dressing the wheel with my diamond and also dressing it more aggressively. In addition to this thread I have emailed Norton about my issue and am anxiously waiting to see what they have to offer.
Thank you for any help.
Aaron
Radiac 8BP46 J8 V8
Radiac RA46 H8 V8
Norton 5SG46-JVS
Aaron
