3D printing PDMS, looking for a low end commerical grade, realiable machine
Results 1 to 7 of 7
    Mar 2008
    Paso Robles, CA
    277
    8
    Default 3D printing PDMS, looking for a low end commerical grade, realiable machine
    Hello,
    Is there a decent 3d printer that can print PDMS material? Looking for something in an low end industrial grade that we can upload files to from solid works and reliable.
    Mike
    May 2016
    CANADA
    Ontario
    308
    74
    108
    What is the application of the PDMS?
    Mar 2008
    Paso Robles, CA
    277
    8
    The application(finished produce) involves processing fluids, the surface needs to have properties, from what I have learned, from PDMS. I guess they are using stereo-lithography but it is slow.
    May 2016
    CANADA
    Ontario
    308
    74
    108
    Quote Originally Posted by landm1 View Post
    "The surface needs to have properties" What do you mean by this? strength properties? corrosion resistant properties?
    if by "using stereo-lithography" you mean the 3D model, you wont be getting away from that cheaply. most printers still require an STL file from what I've seen (Although I may be wrong, it's happened before)
    Mar 2008
    Paso Robles, CA
    277
    8
    PDMS is a type of material. The properties are PDMS interaction with other chemicals, no questions concerning material type. Unless I am missing something 3D printing is done using a 3 axis printer, stereo-lithography is a laser converting liquids into solids.
    What we are looking for is a 3D printer that can process PDMS material?
    Jan 2002
    West Coast, USA
    7,231
    308
    3891
    PDMS is a silicone. It basically congeals to shape when heated up by a laser via stereo-lithography.
    The cheap 3D printers typically use a string of thermoplastic material -- a sort of guided hot melt glue gun -- so those most likely won't be running a silicone.
    If there's a cheaper/faster process from someone other than 3D Systems, Terry Wohlers (Google him) would know.
    Mar 2008
    Paso Robles, CA
    277
    8
    Thank you Pete!
