looking at 3d printers- who's reviews do you believe - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Nov 2011
    Missouri, USA
    2,782
    1354
    2710
    Quote Originally Posted by Motorsports-X View Post
    id honestly not even bother with a 3d printer until someone releases a somewhat low cost laser sintering version. out side of that, if i had to buy one today, and couldnt spend SLS type money... it would be a projet no question.
    Some of the nylons they're developing are pretty tough, but the best material properties are in the SLS range. SLS machines for thermoplastics are cheaper than those for metals. It's a pretty good compromise solution, imo.
    I'm eager to see some cheaper laser sintering machines though. It "feels like" it should be any day now.
  2. #22
    Oct 2016
    Ohio
    Quote Originally Posted by whidbey View Post
    The company I am working with has a solution for the open-loop stepper motor problem without spending the cash on servos, now we just need to get someone to buy the technology and bring it to market. It is super cool to reach into a printer, push the head way off course and see it correct and keep printing. No more missed steps
    Luke
    Sure you don't miss steps but your not going to be able to have the motion profile like a servo has. The servo motor can decelerate coming into a tight corner and accelerate out of the sharp corner. The stepper motor has a jerky movement that creates artifacts in the print. And servos make much less noise than a stepper motor. We are making a large FDM printer and servos are pretty affordable for our application.
  3. #23
    Oct 2007
    NORWAY
    546
    84
    106
    Actually we base the control on snap and jerk (the rate change of acceleration etc) with forward looking planning with history based machine models so we have the whole corner thing under control The system uses feedback so it is by definition a servo system, just one that can be built for a very low cost and has certain other advantages.
    L
  4. #24
    Aug 2016
    Michigan
    7
    We have a MakerBot Z18 at work and I can't tell you how much trouble we've had with it. The first unit was so messed up they simply replaced it. The replacement worked for a few hours and then started failing to the point they brought it back and did a comprehensive troubleshooting process that got it working. It's fairly reliable now, but the company is SO difficult to deal with I can't recommend them. If you don't pay extra, you have to use online customer support that takes days just to get a call or e-mail back
  5. #25
    Apr 2004
    Monument CO USA
    2,058
    9
    107
    These are 1mm thick and 6 inches tall.
  6. Likes whidbey liked this post
  7. #26
    May 2017
    CHINA
    Quote Originally Posted by MaxPrairie View Post
    It's all about layer resolution. If you want a truely smooth part just get it machined from plastic. Especially if you already have a solid model. Find someone/ask the company to print a trial part and see if it is satisfactory if you are hell bent on 3d printing.
    Which type of Aluminum do you supply?
  8. #27
    Oct 2009
    near Seattle, Washington, USA
    1,382
    298
    745
    An engineer I work with had the opportunity to evaluate a lot of different 3D printers at her last job, and she said this one was the most Trouble-free and easy to use.
    DittoPro: Profesional Desktop 3D Printer | Tinkerine | Tinkerine Store
