Lupuscorp
- Mar 20, 2014
- California - merica
Let me start by saying tere are many printers out there that I like. These two offer some of the best features for their respective price and both fall into the specs that I am looking for.
What I want to know or hear are reviews from people who own these and have used them quite a bit.
Please mention your experience with them and pros/cons.
Specifically maker gear 2 and ultimaker 2
Thanks!
Ps this is how I got it down to the two
Multiple material printing
Heated platform
High res
Good components
Solid construction (rigid)
Easy to set zero point
Repeatable
Good organic shape printing res
Possibility for 2 extruder upgrade
Ultimaker 2
Con
Seems to have feeder issues (set screw)
Pro
Lighting
Design
Ui
Software
Chamber
Removable glass platform
Dual fan in te perfect area
Fast
Maker gear 2
Con
No enclosure
No lighting
Pro
Very reliable
Amazing customer service
Cheaper
Most rigid frame
Clean look
Replacement parts easily available
As for materials I'll be using both abs and pla
My primary use will be prototyping parts and seeing how they feel before doing all the work on cam and to make fixtures and stuff for something I might not like (cnc)
I'm an industrial engineer with shop access to 5axos machines mills and lathes.
Most everything will be designed in creo 2 (PROE)
Thanks !!
Thanks!
Heated platform
High res
Good components
Repeatable
Ultimaker 2
Con
Pro
Lighting
Design
Ui
Software
Chamber
Fast
Maker gear 2
Con
No enclosure
No lighting
Pro
Very reliable
Cheaper
Most rigid frame
Clean look
Thanks !!
