Recycle ABS/PLA rejects
Results 1 to 3 of 3
    Mar 2005
    Kauai , HI
    47
    12
    7
    Default Recycle ABS/PLA rejects
    Are any of you recycling the rejects/off spec. print objects? Is it viable financially to grind up and pelletize the rejected objects, and then make new filament using such a machine as this:
    The Noztek Pro ABS and PLA Filament Extruder for 3D Printers - Noztek Extrusion SystemsNoztek Extrusion Systems
    or
    ReDeTec - Professional and Innovative 3D printing technology
    or are these machines require too much attention and turn out crap filament?
    Sep 2005
    South Carolina USA
    4,498
    2154
    1304
    Virgin ABS is only a dollar or 2 a pound.. An injection molder would probably sell or give you 10 or 20 pounds. You would need a granulator to grind up the bad prints, unless they are really small.
    Jul 2010
    Wisconsin
    425
    271
    You will need a spooler to wind the filament. Since the spooler changes the line speed as it winds up and gets larger, you will need a puller to maintain a constant speed. The puller speed will affect the diameter of the filament.
    I would think a single fan will not cool effectively. ABS is not a crystalline resin. With no specific melting point, it will need rapid cooling to stabilize the stream.
