I happen to own a 1929 Ingersoll Rand engine/compressor. It weighs 22 tons. I need to move it from a remote site to civilization. My plan was to make a sled to get it down the mountain to a location we could load it on a lowboy trailer. The sled should also be substantial enough to become a trailer frame if needed. I would like to make the sled of a pair of I beams with cross bracing of the same material. I have located some used I beams (see attached drawing) but I am not sure they will be sufficient.
As you can see from the pictures there is a pedestal underneath the compressor. This is actually the air intake. most of the weight is centered at the flywheel. If we use the sled as a trailer frame the wheels for the unit would be at least 6 feet aft of the flywheel shaft, and the hook would be 15 feet forward of the same.
Any help would be welcome.
