That is what I thought about the RAM. I scrapped off paint and that is the serial no. It reads 2-8892. So, I'm not sure what to think. Maybe first couple were standard machines. Thank you for such a quick reply. I've been watching and reading things on this site, but this is my first attempt at posting here. This site is amazing in the amount of information and experience of people communicating here. Thank you to all that make this possible. I was trying to post pictures (posting from Samsung tablet) but unsuccessful so far. I just starting messing with the K&T mills. This machine seems pretty descent, but have not had it powered up yet. I removed the breather vent on the side of the gearbox in column and internals look beautiful. Oil is clean and free of sludge. Oil sump in base was still full of cutting oil so I think I'm lucky they didn't use water based coolant. I've not been in the knee yet, but that is the next place I'm going to check. I've read post before on importance of motor rotation on these particular units, and need to go back to read again. I'm hoping I can just remove the belts and fire up the motor to check direction. I don't see anything electrical on the motor pulley, all seems to be on the infeed pulley. Anyone have experience on this? This is a very different setup from my other K&T's. I went from 0 to 7 in 3 months. Found them basically just above scrap value or less. So far a 2HL vertical, 3 5hp 2CH horizontals, this 10hp 3CH horizontal, a 4H horizontal with adjustable vertical head (with gear!!!), and a 3KM horizontal. So far it has been a mixed bag as to condition. I assumed that going in. The 2HL vertical is torn apart and in process of getting some parts replaced or repaired and cleaned up. One 2CH had crashed gearbox, other two were pretty nice machines and all internals work and are nice and quiet. The 4H I think will be a parts machine, as I was told some speeds didn't work, but haven't been through it yet. If so I think I'll put the vertical head on the 3KM. I was amazed at the engineering put into the geartrain of these machines. Taking the 2HL apart has been a learning experience for sure. They definitely used water based coolant and a few bearings and seals didn't survive. Luckily the gears and other internals have cleaned up nicely. Sorry to ramble on, I love this stuff! And again thank you.
