Blazemaster
Hot Rolled
- Oct 13, 2009
- Olympia, Wa
I went to go look at a shaper that popped up on craigslist down the street from me, didn't end up buying that but he also had a 14x54 pacemaker in the corner. I gave it the once over and ran it through it's gears, it sounded good. The owner said he didn't use it a whole lot in the 25 years hes owned it. I have always wanted one of these and it was cheap, so I bought it and now I have to get it moved.
I searched and searched for manuals online to see if I could find a weight, the best I could come with was a 1943 catalog listing 5200 as the base length weight, with 450 for each additional 2 feet. That would put it at 5650 if it was the same as a 1943 model. The serial on the side read 71498-49 as best I could see. Just trying to find a weight to deal with the unload, I have seen some of the later ones are as heavy as 9k+. 5650 seems a little light, my k&t 2k is like 6100 and this lathe seems like it has more iron. Maybe its just a bigger footprint...
The machine has a taper attachment, quick release tailstock, leadscrew reverse on apron, steady rest, rusty 3 and 4 jaw, 5 hp motor, micrometer stop and the ways look in good shape. I could not tell if they were the chilled iron ways, or tool steel. It was a dark dusty corner and the machine was covered in years of grime. I did notice it's missing the tailstock handle to move the tailstock.
Thanks for any help!
