TRistick307
- Jan 20, 2018
Hello all,
First time poster here. I am not mechanically inclined so when it comes to actually describing this lathe, please bear with me. My family inherited this beautiful Lodge and Davis lathe several years ago. From what I understand and have seen, it still runs. No issues that I've ever heard of. Definitely needs some love though. I've matched it to similar models in the Lodge and Davis machine tool catalog. Based on the history of this company we can determine that the main body of the lathe dates somewhere around 1886 and 1892. I'm not sure how to even go about dating the actual motor / speed control unit. Before my family and I post on craiglist or ebay, I thought that I would reach out to some knowledgeable folks and see what we can find out about this antique lathe before we go about listing it for sale. From what I've gathered by reading about these older lathes, is that whoever/whomever decides to buy it will definitely need to be a machinist through and through. Unfortunately none of my family, including myself has any idea how to go about describing this piece of equipment to anyone that actually cares. From the research that I've done so far, it appears that the measurements of the swing and the bed are good starting points. To get the swing, I measured from the center of the gap between the bed to the center of the chuck which was about 7". This multiplied by 2 is 14" so if my measurement is correct it appears to be a 14" swing. I wasn't sure how to get an accurate measurement of the bed. The entire length of the lathe is about 8 ft. If I'm excluding the headstock, the bed is about 7 ft.
Oh, and yes... this lathe is in our basement. It should make for an interesting removal.
Here are a few questions that I have for you all.
1. What other key things are you guys looking to know about this lathe if you were purchasing it?
2. What are some of the factors that help best determine the value of this lathe?
3. Are there any additional photos (other than the attached) that would be helpful for determining the overall condition and capabilities of this lathe.
4. Do you have any additional information about the history of this lathe? Links, resources, etc.
I'll be monitoring this post for awhile, so if you need any additional information or pictures, I should be fairly quick to respond.
If anyone is located near Portland, OR. or you know someone out this way that may be interested, definitely feel free to message me directly.
Thanks in advance for your time and thoughts!
Travis
Travis
