Ben,
But why take off the electric drive if it's an antique also?
I have a Flather 12" shaper with what I think may be a factory drive. 4 speed unidrive, or what looks like a unidrive box, no plate or name cast in that I have found, and a G.E. 1.25hp repulsion induction motor. They are mounted on some real nice brackets, cast, not fabricated. Don't know the age of this machine, I think WW1 vintage, it has 1/2-13 threaded bolts so it was made after 1917? I knew when they changed the standard once but I forgot. But anyhow I consider it an antique.
Also have a good sized, 27x131, New Haven Engine Lathe built I think, about 1880. Its well laid out, lead screw on front, no interlock on halfnut, but the handle when disengaged is down and gravity keeps it there, you just don't want to get stupid and engage it when feed is engaged. The threads on the tailstock screw are right handed, so the hand wheel turns backwards. It has some other strange features. Guess they were still learning how to build them then, it is serial #29, #30 was prabably different.
But back to line shafting, this machine also has an electric drive, real nice, with clutch and a 4 speed white truck transmision belted to an Allis-Chalmers 2hp open frame motor.
I guess they were installed maybe in the 40's because of the electric welding used in making of the brackets.
Is it still an antique with this drive?
I think that maybe it's still is an antique if it has a Model A Ford transmission on it.
Got a steptoe shaper with a model A trans. on it, take $100 for it and leave the single phase GE? or was it Westinghouse? motor on it.
I am glad that we do have people setting up machines with line shafting, have always wanted to see a shop in operation that way. Have only seen one machine operated by an overhead shaft and it was hooked to an electric motor. The old man running it flipped them belts arround with it running, scared me, but I was younger then, bout 14.
I later worked for this man, learned a lot from him, I think he's antique class now.
He don't chew bakker though.
Have fun everyone
