I recently acquired a Logan Model 200 lathe to replace an Atlas/Craftsman 12 X 26 lathe. Now I can hold my head up high on this forum, instead of slinking around and having to admit that I have a "lathe-that-must-not-be-named".
I kept some of the accessories when I sold the Atlas. The headstock taper and threads were the same on both lathes, so most accessories would interchange.
One of the accessories I kept was an Atlas milling attachment.However, it won't directly interchange. On the Atlas lathe, the compound is removed, and the milling attachment fits over the dovetail on the cross-slide.It is locked to the cross-slide with two angled pins. The Logan lathe doesn't have the same type dovetail on the cross-slide, so I'm going to have to make some sort of adapter for it.
Has anyone here adapted a Logan lathe to fit an Atlas milling attachment? I have a couple of ideas, but I'd like to hear how someone else has done it, so I don't re-invent the wheel.
Thanks for any advice.
Rick W
Rick W
