djones3158
- Jan 19, 2012
- west virginia
Just got my No 2 light Brown and Sharpe milling machine running. Not sure how much oil kevel needs to be in knee. No sight glass, just a fill cup. So I filled the fill cup to the point oil is standing in the cup and it runs out at a pretty good rate for a few days. So, I'm not sure if I might be overfilling it or not. I do know according to the information that I do have is that the oil system does hold pressure after the machine is shut off for a good while. I also know the drip glass for the knee is not showing anything when knee is feeding. When I lay on my back and look up under the knee I see that the open drip system is pumping oil to various gears and bushings so these things have to leak oil while running. I also notice a what looks like a 5/16 copper line with a fitting on the end not hooked up to anything and don't see anyplace to hook it up to, but no oil is coming out of it. If I can't figure it out I guess I'll drain oil sump to see how much oil is in it after it slows down. I'm hoping the drip glass will "heal" itself. I was unaware of the problem before I had the knee off for painting a few years ago, and now the machine is in place with no overhead beam so I hate to take it apart again but may have to. Thanks for your help.
