Cincinnati metal turning lathe. 16" swing. Will turn 60" between centers.
220 volt SINGLE phase motor. Can also be wired for 115v.
Overall length is 9 ft. Width is approx 36". Height is 5'9". Weight is approx 2,000 lbs
Flat belt drive with a 2HP Cullman conversion. Complete and in good working condition. Normal wear for a lathe this age. I have it wired up and running if you want to test it out.
Has a quick change gear box and will thread from 2 - 28 tpi and feed from .008 - .120 per rev
Includes the following:
- 8" 3 jaw chuck
- 14" 4 jaw chuck
- live center / drill chuck for tailstock
- drill chuck with taper shank to fit tailstock
- 3 tool holders
- steady rest
Located NW of Oklahoma City in Piedmont, OK. Can load on your trailer or possibly deliver nearby if you can unload on your end.
$900
- 8" 3 jaw chuck
- 14" 4 jaw chuck
- 3 tool holders
- steady rest
$900
