kqua
- Mar 20, 2013
- New Hampshire, USA
I have an old 15" Hendey shaper #765 I'm restoring. A couple of teeth are broken on one of the ram's drive gears. I need to remove the drive gears so I can repair the teeth.
Don't want to break anything. Any thoughts on removing them? There is a collar on both sides of the gear shaft-it doesn't move. Also bad is the drive gear on the side of the machine. It has cracked webs which I may vee and braze. One rack is bad. And the tool bit compound was broken on one side- someone pinned it, making it functional, but down the road I may make another. Any other info on this shaper would be great.
Tried to upload photos, but just had a spinning ball- maybe it's Mac's Safari?
thanks for any help
thanks for any help
