projectnut
Stainless
- Mar 4, 2006
- Wisconsin
I added this post to an older on about Racine Power Hacksaw, but felt I might be able to get more responses by starting a new thread.
Some time ago I bought an older saw and am now in the process of cleaning it and restoring it to it's original state. I've finally gotten the saw disassembled to the point I can start cleaning off the years of crud. It's been a long and slow process with dozens of interruptions, but it's now in manageable size pieces that can be cleaned individually. A few days ago I tried several petroleum based solvents which all yielded less than satisfactory results.
I'm guessing the coolant that was used was a water based one similar to the bandsaw coolants. Over the years it's combined with the swarf and turned to a sandpaper type grit that defies removal. So far the most successful method has been to use dish soap and a scrub brush. It's worked far better than any petroleum based product, but takes an inordinate amount of work to get a single piece clean.
I'm thinking about trying something like heavy duty oven cleaner, then a bath with the pressure washer. I'm sure others have encountered similar problems removing years of residue from older machines before restoration. I would appreciate any suggestions on techniques and products that might speed up the job.
The single response I got on the other thread recommended ZEP degreaser. I happen to have a couple cans on the shelf and thought I'd give it a try. If there are any other suggestions I appreciate them.
