R
romvlvs771
Guest
My name is Sergio, I am new to machining and this is my 1st Milling Machine.
Recently I bought a Diamond Tool Company B-12 milling machine.
I have it running and just ran into an issue, maybe someone could shed some light to resolving this issue. This is a horizontal machine with the vertical arm is set and there is a Jacobs #32 3/8 tapered chuck in there I was milling a piece of aluminum and 2 hours into the job the tapered chuck came loose.
Now when I push the chuck back into the tapered shaft, back in I seems to stay but when I attempt to mill again as soon as the milling bit starts to work on cutting the chuck slips off.
My questions are:
How do I remove the taper shaft where the chuck slips into?
(I did remove the screw that apears to be holding the taper rod, but it sitll did not come out)
What options do I have to add new cutting bits, I would like to go to a 1/2" tapered chuck as I have larger bits?
Also does anyone know of a manual for this B-12 ?
I have included some pictures, any help is greatly appreciated.
Thank You,
Sergio
My questions are:
Thank You,
Sergio
