I still think it's a frankenlathe. And here's why.
-Strange dovetail ways that could have been cut in another lathes bed.
-Head and tail stock are not in the centre of the ways.
-Missing lead screw. And is don't see mounting holes for a lead screw.
-Weird offset tail stock. That base just doesn't look right.
-The clamp that holds down the carriage look homemade.
-I can't find this on lathe.co.uk so I think someone bolted on that made in Holland badge.
(The stand and bed might be AI Hembrug not the DR1 that could explain the made in Holland badge)
Ok let me put the counter argument:
Cutting a new dovetail is way beyond your typical Frankenstein and where did the head stock , which neatly mounts on said dovetail, come from ?
There are plenty of lathe whose spindle centre is not on the centre line of the bed (my hlv-h for one) . Placing the support for the cutting tool under the line of force is simply good practice.
The missing lead screw is also missing mounting brackets that contain your missing holes ;-)
The tailstock only looks wrong because someone has chosen to paint part of it.
If there's a homemade clamp holding the carriage, it's because the real clamp is missing
There are plenty of holes to fill in Tony's machine list (i know, i filled one- Have a look at the Haigton Major , it wasn't listed until i found one , ive since found five more and an updated HSU2 model, still not listed on the site)
Why I believe it to be a whole:
Everything fits - sounds simple but unless bits are made to the same pattern i.e copies, they just don't fit. Here the headstock fits the bed , the carriage positions the slides correctly, the tailstock aligns , the bed fits the base , the counter shaft fits the base the covers fit , No way are any of these bits been made for other lathes and can be accidentally reassembled the form another whole.
The plaques are correct : Frankensteins don't cast matching badges and tables for their monsters. Look at the design of the PDF badge , made in england badge and the 'groot handle' badge each has the same fine hatched background , made by the same maker for sure.
I also noticed the similarity to the hembrug but that is nothing unusual , designs are not created in isolation.
Bill
