Frank R
Stainless
- Dec 18, 2009
- Dearborn, Michigan
I recently acquired this old milling machine head. The label on the motor says "Electro Machines Inc., Cedarburg, Wisconsin".
It looks like it is from the 1920s or 1930s. It is 1/3 HP and 3 phase.
Some googling around found that the motor is from Electro Machines but probably not the rest. I thought the company might have evolved into Electro-Mechano Instruments of Milwaukee, Wisconsin but they emailed back very quickly that it was not. I cannot find any other labels.
The fine feed wheel is nice and smooth.
It has a Morse 3 taper with one collet.
The collar is graduated at one end for rotation. It looks like it fit into a very large bracket that I am guessing fit over a horizontal mill arm. The collar is a good 6-8 inches in diameter.
The switch is located on the back of the motor, opposite from the spindle end (upper right hand corner of photo). This makes me think it was mounted crosswise to the over arm and parallel to the table.
A neat feature is the mechanical counter on the front. It clicks by as you rotate the find feed wheel.
Does anyone recognize this head?
There is a fourth image there at the end; easy to miss it.
