sandiapaul
Titanium
- Mar 19, 2004
- Princeton, NJ USA
After many months of rebuilding I finally have everything together on my lathe and have a problem with my flat belt not aligning properly. The lathe is a Smart & Brown 1024. I added a new motor and made a new way to mount the motor. The original motor hung down from the plate the gearbox is mounted on. I mounted the motor on a plate that uses standoffs that mount to the late as seen in the pic. This is likely the source of my problems I realize. Perhaps the shafts are not parallel, or???
I can't get the belt to track in the middle of the pulleys. Worse it comes off at higher speeds. See the pic, motor is at the bottom, it drives a two speed gearbox at the top. I have lots of room on the motor shaft to move the pulley in and out, but that does not seem to help, best I can make it about what you see in the pic. About 3/16" of the belt is off the pulley.
If anyone can offer some advice on which way to move or shim my motor mount I sure would be grateful! Alternatively would another type of belt do better?(wishful thinking I know)
