Mad Machinist
Cast Iron
- Oct 24, 2006
- Sharon, PA
We are currently installing a 60" x 60" x 24' 4 Head Gray Planer. This is the third big Gray machine we are putting in. It will be the smallest and by far the oldest. It doesn't have the Space Saver drive and it's serial number barely clears 7000. It's next stop probably would have been the scrap yard. Anyway I have a question on Gray's lubrication specification that nobody has been able to answer. Not even a retired Gray (G&L) guy I know.
All the lubrication specifications are in Gray's Bulletin 59. Gray specifies Gargoyle Arctic "C" for the rail end gearbox and side head gearboxes. It's scratched out on my copy but it says on 72" and larger Openside and 84" and larger Double Housing use DTE Light. Also on a Gray Shell spec. sheet it says to use Shell Vitrea oil 29. It has the same "note" but the note also specifies Vitrea 29 for the larger machines. Vitrea 29 must be an outdated spec. I can't find anything about it.
Arctic "C" is a refrigeration oil designed to work at sub zero temperatures. Gray must have specified it for a reason. Does Anybody know why?
