JimK
- Apr 25, 2003
- Berkeley Springs, WV, USA
Comments on the shaper topic lead me to post this on the heavy lathes out there.
Some of this I have said before so bear with me.
In the early 1950's just after the war, The American Tool Works, Lodge and Shipley, Monarch and R.K. LeBlond understood that cutting with carbide tools required a completely different kind of engine lathe.
By 1955, there were:
The Lodge and Shipley PowerTurn
The American Pacemaker Style B,C,D,E and F with number designations (1610-2513).
The Monarch Series 60 and later series 6XX
The LeBlond NE, NI, NF, etc. (not the Regals)
These machines are actually super-lathes.
They are designed for production turning of tough steels in small lot quantities. Manufacturers of printing machinery, paper machines, special process machines, large pumps and large electric motors would be examples of the users of these super-lathes.
A lathe may be assigned shaft work in lots of 20 to 80. Set ups change frequently, work is carefully routed to each lathe according to the size and power available, roughing and finishing may be divided amongst two or more lathes.
Power is the key word. 10HP is the ante, 25 to 30HP on a 16 inch lathe was not all that unusual.
Now, let's imagine a rotor shaft for a big electric motor. It may be six inches in dia. at its largest part and at least four feet long.
This baby would go on a 1610 or a 2013 size of any of the above machines.
At least one of the cuts will be three feet long. Let's get freaky and say the shaft is 4140.
Here is what Monarch thinks you should do. Set the spindle speed so that the work is going at 400-500 SFM. Then take a nice .250 depth of cut for roughing. You can then feed the tool at from .010 IPR to .020 IPR.
Remember our first cut is three feet long. Wanna try that?
You are throwing power at the work. The carbide tool requires high speeds and it also requires very aggressive feeds.
The head stock has to stand up to that all day long, you have from 20 to 80 of these shafts to run.
The feed works has to move the carriage against the resistance of the tool in the cut. All the gears from the spindle to the bed rack have to be able to stand the stress not just once, but all day every day!
These lathes step right along. More power is going through the feed works than most lathes have at the motor!
That is what I call the transmission capacity of a lathe. Can a lathe get power from the motor pulley to the point of the cutting tool?
As if that wasn't enough, along comes the hydraulic tracer. Basically, hit the feed clutch and forget about it. Spindle speeds inch up, feeds get a tad more aggressive. The lathe works longer shifts and spends less time down for change overs.
Super-Lathe saves the day!
Now. some of you are fortunate enough to run or even own one of these babies. Unless you have done the equivalent of manufacturing engineering on the work piece and the set up, don't try the above messing around!
A job like my hypothetical motor shaft would go through the Progress and Planning Dept. then through Tool Engineering and then might be vetted by the Monarch Technician. That technician might even give you a copy of form No. 3613 from 1957. "Speeds and Feeds for Better Turning Results".
These lathes haven't got any sense. They think they are on the floor at General Electric or Worthington Pump. They will go right ahead and do anything that you are fool enough to ask them. If you or anyone else think that you can casually throw 20 HP at a job held in a three jaw chuck, think again.
If you haven't got a tote with forty 4 inch diameter shafts sitting next to your lathe, then you should treat your Monarch or PowerTurn or Pacemaker of NE LeBlond like an ordinary tool room lathe. They are the best there ever was and they do the light and the medium stuff better than any other make or model of lathe.
Just remember, there is a whole 'nother world out there that those lathes are comfortable with and you might not want to go there.
