help with identification?
Results 1 to 11 of 11
    May 2008
    Fort Worth TX
    Default help with identification?
    Hi folks, I'm new here and very much at a loss. I picked up this old lathe and can't find any markings that identify it. The little nameplate that was on the gearbox cover has been lost apparently. Here are a few pictures.
    Thanks in advance.
    B.
    Jan 2002
    Sea Cliff, NY & Portland, OR USA
    745
    98
    61
    Flat ways, sheet metal gear cover, shape of spokes on countershaft pulley: early Atlas--perhaps 1930's 9 inch?
    Tom B.
    Feb 2006
    Indiana
    11,968
    446
    3145
    The headstock is more like the Atlas 10"; the 9" had a very different appearance. See this:
    http://www.lathes.co.uk/atlas/index.html
    Larry
    Apr 2008
    London, UK
    123
    Looking at the lack of ribbing on the headstock, it could be a very early 10" Atlas (see http://www.lathes.co.uk/atlas/page11.html, has the same tool holder) but with a later gearbox and apron added
    Apr 2005
    MA, USA
    2,053
    10
    It's certainly Atlas-based. Overall looks like an early 10" but the feed gearing is different. Maybe a machine made for a third party.
    Feb 2006
    Indiana
    11,968
    446
    3145
    It is a very good match for the 1935-36 Craftsman 12" lathe. About the same as the Atlas 10", but with the tool post T-slot part of the compound raised 1" and the headstock and tailstock similarly 1" higher. Note the distinctive handwheels for the cross feed and compound feed. The butcher's lathe has had the knurled(?) compound wheel customized with an additional crank handle fastened over it.
    http://www.lathes.co.uk/craftsman/page2.html See the third picture from the top.
    Larry
    May 2008
    Fort Worth TX
    Default Thank you all very much!
    I believe you are correct! I was looking for the little reversing lever over there by the somewhat home made looking switch box. I am assuming of course that the lever in question is indeed for reversing the direction. It won't move...LOL. I suppose the 50 dollars I spent on it was worth it? It came with a brand new self centering three jaw chuck, what appears to be the "standard" chuck, and the one that is on it in the picture as well as many change gears, lots of cutters, and a handful of goodie bits and pieces.
    Thank you all for your generous help!
    S.B.
    Quote Originally Posted by L Vanice View Post
    It is a very good match for the 1935-35 Craftsman 12" lathe. About the same as the Atlas 10", but with the tool post T-slot part of the compound raised 1" and the headstock and tailstock similarly 1" higher. Note the distinctive handwheels for the cross feed and compound feed. The butcher's lathe has had the knurled(?) compound wheel customized with an additional crank handle fastened over it.
    Larry
    May 2008
    Fort Worth TX
    Default One more question?
    Does anyone here know where I might find parts and pieces for this thing? Obviously the gear cover is in need of replacement, and one of the change gears is shattered. I really need a manual to see if there are pieces I'm missing, but that may be asking a bit much for a lathe that's 73 years old.
    Butcher.
    Feb 2006
    Indiana
    11,968
    446
    3145
    The gear cover looks like an easy straightening job, and you won't find a new one for sale anywhere anyway.
    If Atlas did not change the size of their change gears after 1936, then there are usually a few on eBay or you can buy a new one from Clausing. They sell manuals for the late model lathes, but much will still be valid. You might see a reprint of an older edition on eBay. Clausing will ask for a model number, which may not be on your lathe any more. There is plenty of information on the web, so you should be looking there. Here are two key places:
    http://www.clausingsc.com/sc-home.htm
    http://www.bellsouthpwp.com/t/h/thib..._Lathe_FAQ.htm
    Larry
    May 2008
    Fort Worth TX
    Yes, I suppose I could straighten what is there of the gear cover, but the actual door of the cover is gone. It appears to have been made of sheet metal from the pictures I've seen, Ebay has a lot of cast covers for slightly newer models of this lathe, but nothing resembling the sheet metal. I'll check out these links and see what I can find. Thank you again!
    Butch.
    Larry
  11. #11
    Apr 2008
    London, UK
    123
    Quote Originally Posted by StainlessButcher View Post
    Butcher.
    http://www.lathes.co.uk/manuals/ has a manual listed, search for MC500G
    "MC500G CRAFTSMAN 12-inch LATHES - a clone of the Atlas 10-inch - click here for pictures Various Models including: 101.20280, 101.20300, 101.20320, 101.20650, 101.20670, 101.20690, 101,20710, 101.20730, 101.20750, 101.20770, 101.20790, 101.07360, 101.07361, 101.07362, 101.07363, 101.07380, 101.07381, 101.07382, 101.07383, 101.07400, 101.07401, 101.07402, 101.07403, etc.
    A complete package of information that covers all models from the original 1930s lathe (a clone of the Atlas 10-inch) to last version in 1958. It includes:
    1) a very comprehensive Manual with over 240 pages that contains detailed Operating & Maintenance Manual and extensive thread cutting charts - it's probably the best lathe instruction book ever produced by a lathe manufacturer.
    2) extra instructional sheets, but never included in the main Manual: taper turning attachment; fitting new leadscrew nuts, steady rests, adjustable bed stop.
    3) a complete, Illustrated Parts Manual with exploded diagrams.
    4) a set of reproductions of the original advertising material (some very rare) that give a complete technical specification for the lathe, shows changes over the years and illustrated lists of all the accessories.
    £30 on CD
    £45 Printed
    US$54 on CD
    US$80 printed "
