steelfronts:
Since the circa of manufacture has now been established, 1901 to 1904, a Serial Number is not required to find the correct drawings.
Very few design changes occurred during this period with regard to the lathes, the most notable being the addition of the Compound
Gear Box in 1904. Determine what parts you need and I will check the drawings. Keep in mind that not all of the drawings have surivied
as hard copies, but are preserved on microfilm and when printed out are a smaller size than the original. Hendey did not make
exploded views of assemblies, but standard three view drawings. Until about 1912, individual part drawings, one part per drawing, was
not used by Hendey. During the period that your lathe was built, the standard was to group a number of parts from the same assembly
on one drawing and put several assemblies on the same drawing. This is one of the reasons it is so time consuming to find a particular
part used on the early machines. Despite any title on the drawing, it is necessary to check each part on the drawing for the name of
the part, the part number and the number of pieces required. On a few occasions, I have found parts from two different machines on the
same drawing. Be patient, it may take a bit of time to find the drawings you need.
Hendeyman
