History and pictures of H.W. Kearns boring mills
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 129
    Feb 2011
    Pensacola, FL
    1,299
    152
    791
    Default History and pictures of H.W. Kearns boring mills
    Since owning one of these boring mills, I often researched on the internet history and info on these machines.
    heres a link to some history of the Kearns company.
    A BRIEF HISTORY
    Just look at all the tooling they marketed with this machine!
    This one is much like mine, only a bigger table.
    Feb 2011
    Pensacola, FL
    1,299
    152
    791
    I love the look of the black paint. I want to re-paint mine to look the the ones in the pics.
  3. Likes richard218, ernieflash liked this post
    Feb 2004
    Metuchen, NJ, USA
    5,313
    3821
    775
    I count more than a dozen wrenches and spanners. Some of them look fairly specialized.
    In as much as it's British, is your machine new enough to have metric fasteners, or does it have Whitworth fasteners? If so, I hope you've got all the wrenches!
    John
  5. Likes Joseph Ywayan liked this post
  6. #4
    Jul 2010
    Netherlands
    44
    35
    Default Kearn boring machine
    Some pictures of my Kearns boring machine. It came without a counter bearing/tailstock bearing or whatever it's called and the faceplate is something I cooked up myself. the spindle is a MT4. Is the secondary slot in the taper (3rd picture) part of a system to lock the tooling in the spindle?
    More pictures can be found here;https://picasaweb.google.com/jos5414...BoringMachine#
    Jos
  7. Likes pressbrake1 liked this post
  8. #5
    Feb 2011
    Pensacola, FL
    1,299
    152
    791
    Josv,
    You got a nice mill too. Looks a little smaller than mine. My spindle is 3" with a #5MT. As for the second slot in the spindle, Im not sure exactly how its used. I always put the drift in the rear slot to knock the tools out. So did your not come equipped with a facing chuck?
  9. #6
    Feb 2011
    Pensacola, FL
    1,299
    152
    791
    I dont have any pictures that I can find, but I did build a mount for an old 4-jaw chuck and can set up the mill like a lathe. For the tool post, I built a riser mount that bolts to the table, and I also machined two different bushings for the tail stock, one will fit another smaller 4-jaw chuck, and one that takes a straight morse taper sleeve. Its a very versital machine. Set ups just take a while.
  10. Likes Edgar10937 liked this post
  11. #7
    Jul 2010
    Netherlands
    44
    35
    Default Kearns boring machine
    ABom79,
    When I got the machine there was no face plate or chuck but looking at the spindle nose (see picture) I think something has been there in the past. There is no date of manufacture but I guess 50's/early60's, what year is yours?
    Jos
  12. #8
    Mar 2005
    Somerset, UK
    4,928
    385
    1406
    Abom,
    I much enjoyed your other thread (about your machine shop, showing your Kearns machine earning its living while sunbathing).
    You said that you wanted to paint it black. I have seen a Richards horizontal borer in black, and it did look very smart. (Kearns and Richards were neighbours, and eventually merged). A lot of Manchester machine makers favoured dark green before the early 1950s.
    In the 3rd and 4th photos in your post #1 above, the work piece on the table is actually a test piece. Kearn’s supplied every borer they made with such a test piece produced on the machine, using all the various functions. The pictures below should explain. Taken from The Engineer 5th September 1913. Unfortunately acceptance standards aren’t quoted.
    Clickable thumbnail:-
  13. #9
    Nov 2004
    Birmingham, AL
    12,714
    5543
    2238
    Second slot in spindle is for a lock key, the equivalent of a drawbar for this machine. If you are working with a boring head, the head will have a matching slot on the shank so you slide it in the spindle, bump it with a 2x4 to lock, then insert the key and bump it to lock the key. Now your boring head cannot pull out. You also see this on big radial drills, where it is even more critical, what with gravity working against you.
  14. #10
    Jul 2010
    Netherlands
    44
    35
    Default Locking device
    Quote Originally Posted by Mike C. View Post
    Thanks, I assumed it was something like that. Some of the tooling that came with the machine has this extra slot. I've seen more MT shanks with it and I noticed the slots in spindle and shank are orientated in such a way that inserting a wedge pulls the tool in, contrary to the regular slots. I just wonder how the actual key looks. It would have to be flush or lower than the spindle O.D. otherwise the spindle can't fully retract and I guess it has a positive lock to prevent it from flying out at higher speeds.
    Jos
  15. #11
    May 2006
    Edmonton
    236
    23
    40
    Default Kearns picture
    Just thought I'd include a picture of the old girl I used to run... Mess and all.
  16. Likes ces224 liked this post
  17. #12
    Apr 2006
    Manchester, England
    6,255
    726
    3148
    Great to see the photo's guys , brings back lots of happy memories. At some time in the past I've worked on machines like all those in the photo's.
    Abom 79, you're a lucky guy if you got a little wide bed machine like the one in the photo, look after that and it'll last a life time in spite of the old " Kearns " patent belt drive. They still made their early numerical control machines with the same flat belt drive !
    Josv, I think your is an early " O " type, maybe an " OB " , that's an unusual top table . If it's a revolver how do you locate it ?
    Pat , I remember a labourer cimbing onto the balance weight to sweep down the back of the column on one just like yours, he'd been to the pub at dinner time and he managed to fall off the balance weight and cut his head open. Having said that standing on the weight was tricky even when sober.
    The first slot in the spindle from the end is for a locating cotter pin as Mike C said, usually just a tapered piece of metal hammered in by some heavy handed operator. They seemed to hit the spindle more than the pin every time the put the pin in. An italian firm called " Bakur " used to make an adjustable cotter pin that worked very nicely as long as you fitted it the right way around. If you fitted it the wrong way around it was usually a complete travelling spindle out job, don't ask how I know ! Regards and thanks again for the photo's. Tyrone.
  18. #13
    Feb 2011
    Pensacola, FL
    1,299
    152
    791
    Heres another picture of my Kearns during a facing job.
  19. Likes starbolin, Edgar10937 liked this post
  20. #14
    Feb 2011
    Pensacola, FL
    1,299
    152
    791
    In this one you can see all the tooling we made for the machine. Some are job specific.
  21. #15
    Feb 2004
    Metuchen, NJ, USA
    5,313
    3821
    775
    I guess nobody thought my comment / question about Whitworth threads was worth a whit.
  22. #16
    Feb 2011
    Pensacola, FL
    1,299
    152
    791
    Quote Originally Posted by SouthBendModel34 View Post
    Honestly, i believe the bolts are metric. I havnt taken apart but a couple pieces of the mill and the bolts I removed for metric allen cap head bolts.
  23. #17
    Apr 2006
    Manchester, England
    6,255
    726
    3148
    In my experience all " Kearns " machines of that era ( all the machines in the photos will be pre the early 1960's at least ) would have Whitworth screws. They only started to go Metric in the 1970's. Regards Tyrone.
  24. #18
    Sep 2004
    south SF Bay area, California
    1,839
    83
    491
    Asquith --
    Kearns' machine acceptance criteria for Test Piece errors can be found on Q S Machine Tool Service's website.
    TEST PIECE
    John
  25. #19
    Mar 2005
    Somerset, UK
    4,928
    385
    1406
    Thanks, John, I missed that.
    I think some of those tests are quite challenging - especially the ones where you have to rotate the workpiece (e.g. on the rotating table) to machine the opposite face.
  26. #20
    Apr 2006
    Manchester, England
    6,255
    726
    3148
    Hi John and Asquith, The Kearns machines had a patentened device consisting of a hardened and ground tongue fitting into hardened and ground sockets let into the revolving table to locate the table at 0-90-180-270-0. You can see it in the middle of the table on some of the illustrations and photo's earlier. The sockets were shimmed into place with very thick shims. They were usually very accurate and that particular test could be achieved with a modicum of time and effort.
    Abom 79, How did you learn to set and operate your machine ? Are there many machines with built in facing slides in your neck of the woods ?
    Regards Tyrone.
