New member! I just bought one of these machines... in partially restored condition but with some parts missing. I need to find out as much as possible in order to have any hope of getting it running. I joined this forum in hopes of finding information. I own a very small private mint making fantasy coins for the geek market.
Home : shirepost.com Die-making is the bottleneck and I am hoping that this machine will give us one more method, and the ability to create pattern reductions and mirror copies.
There is no maker's name anywhere on the frame. The gears are marked Brown and Sharpe, but I think they are just parts.
The basic configuration is that the master pattern and the reduced copy both rotate s-l-o-w-l-y in unison while a stylus rides the master and controls a cutter to make the reduction. The main gearing system is for rotating the master and copy. A subsystem slowly traverses the stylus across the face of the master so that the cutter makes a very small increment of travel for each rotation. I understand that it can take twelve to twenty hours to complete a full pass. This leads me to think that the motor must already be a gear-reduction type even before the pulley system is engaged, to get the speed down slow enough. The parts that are missing are mostly the motor and main drive pulleys. I think there is at least one jackshaft for slowing down rotational speed... possibly two. I can try it with a standard speed motor, but I'm afraid it will be much too fast.
Other than that, the operation of the thing is fairly obvious. There is a clutch to switch rotational direction, but there is no handle or actuator for the clutch... not sure where it's supposed to be or how it's attached. IThere are a couple of brackets that are obviously for doing something... but whatever they do is not clear. I'm at the point of trying to sleuth out the operation by examining wear marks and set-screw scars, trying to deduce what was attached where, and why.
I will probably replace the power-take-off cutter head with a newer electric or air powered spindle, and there is supposed to be some sort of counterweight system for maintaining pressure on the stylus... all missing
I concur that the amount of information available about these machines is very small. I would love to find out if David Wood-Heath has written anything.
If anyone can point me towards any information I would be much obliged!
Tom Maringer
Shire Post Mint
Springdale Arkansas
Yes, it was indeed David Wood-Heath I am talking about.
He showed slides of his home/shop (the two run together), with something like 40 lathes IN the house.
He has a wide range of these reducing lathes, most likely more than anyone else on earth.
I think the sum total of information on these machines is very small. I dont know of any books that talk much about them at all. Certainly there is almost nothing online.
